In ultima perioada nu am stat degeaba si am realizat niste etaje finale mici, mai "domestice" home use.
Sint un hibrid intre Leco V2 si Leco V3 ca topologie, insa un etaj final lasat "liber" sa zburde ca pasarea cerului in ceea ce priveste domenul de frecventa reprodus, si timpul de crestere extrem de mic.
Dar sa las pozele si filmarile sa vorbeasca, voi dezvolta pe parcurs ultimele noutati.
Citeva teste "preliminare":
Raspuns in frecventa, tensiune iesire cu si fara sarcina, test pe capacitiv, dreptunghiular, rise time:
[video]https://www.youtube.com/watch?v=lFXPlqukBMA[/video] slew rate-ul il calculati voi daca doriti.
Sarcina 4 ohmi, 2 ohmi si scurt pe iesire:
[video]https://www.youtube.com/watch?v=xr-HjpH ... e=youtu.be[/video]
http://i63.tinypic.com/fk09l3.jpg" onclick="window.open(this.href);return false;
Continuare, o mica "arta"
http://postimg.org/image/q9yha84cv/" onclick="window.open(this.href);return false;
http://postimg.org/image/3zama972n/" onclick="window.open(this.href);return false;
http://postimg.org/image/9id5rh43z/" onclick="window.open(this.href);return false;
http://postimg.org/image/72bcdmm1b/" onclick="window.open(this.href);return false;
http://postimg.org/image/rwnovggen/" onclick="window.open(this.href);return false;
http://postimg.org/image/3rmzdqw3z/" onclick="window.open(this.href);return false;
http://postimg.org/image/ct6453jf3/" onclick="window.open(this.href);return false;
http://postimg.org/image/hk5zn4c9b/" onclick="window.open(this.href);return false;
http://postimg.org/image/66jgbx1qn/" onclick="window.open(this.href);return false;
http://postimg.org/image/55em91vdb/" onclick="window.open(this.href);return false;
http://postimg.org/image/okpe25onj/" onclick="window.open(this.href);return false;
http://postimg.org/image/vmrx23hn3/" onclick="window.open(this.href);return false;
http://postimg.org/image/uup92wdfz/" onclick="window.open(this.href);return false;
http://postimg.org/image/mt10kzuof/" onclick="window.open(this.href);return false;
http://postimg.org/image/8exmt98un/" onclick="window.open(this.href);return false;
http://postimg.org/image/drmh7dwr3/" onclick="window.open(this.href);return false;
http://postimg.org/image/hy7bmpwcv/" onclick="window.open(this.href);return false;
http://postimg.org/image/6vxnajcwf/" onclick="window.open(this.href);return false;
Acum masuratori ca la carte:
http://postimg.org/image/4yegg5wr3/" onclick="window.open(this.href);return false;
http://postimg.org/image/bnkzw6i33/" onclick="window.open(this.href);return false;
http://postimg.org/image/tp44tzc3z/" onclick="window.open(this.href);return false;
[video]https://www.youtube.com/watch?v=-ofV55e ... e=youtu.be[/video]
Raspunsul armonic si THD, THD+N la circa 10W/8R:
http://postimg.org/image/jxkaqobnz/" onclick="window.open(this.href);return false;
Raspunsul armonic si THD, THD+N la circa 1W/8R:
http://postimg.org/image/n34wgvua7/" onclick="window.open(this.href);return false;
Am testat la 9kHz (scuze unde mai zic 10kHz in filmare) la 32,6Vrms la iesire, si un test gen IMD cu 2 frecvente 60Hz si 7000Hz in raport de circa 4:1, rezultatele sint urmatoarele:
Filmarea 9kHz la 32,6Vrms:
[video]https://www.youtube.com/watch?v=WAYQcqB ... e=youtu.be[/video]
Captura fara sarcina la iesire:
http://postimg.org/image/cpr1kcsgf/" onclick="window.open(this.href);return false;
Captura cu sarcina la iesire:
http://postimg.org/image/5b1prz6kv/" onclick="window.open(this.href);return false;
Filmarea cu 2 frecvente 60Hz si 7000Hz raport de circa 4:1
[video]https://www.youtube.com/watch?v=0PogOHd ... e=youtu.be[/video]
Captura test 2 frecvente:
http://postimg.org/image/5p7n5bg27/" onclick="window.open(this.href);return false;
Din nou teste:
Noise level cu intrarea in scurt si 8R la iesire:
[video]https://www.youtube.com/watch?v=VhWWt26nlQo[/video]
http://postimg.org/image/n5p8n3evj/" onclick="window.open(this.href);return false;
THD la 1W/8R intre 1000Hz si 11000Hz, unde spun THD 0,03%, este DUPA virgula, mai gresesc si eu...
[video]https://www.youtube.com/watch?v=ot8jaUj ... e=youtu.be[/video]
http://postimg.org/image/bvwis59u7/" onclick="window.open(this.href);return false;
http://postimg.org/image/r3cici1ov/" onclick="window.open(this.href);return false;
http://postimg.org/image/r5wdzc5cf/" onclick="window.open(this.href);return false;
http://postimg.org/image/7cka6mryn/" onclick="window.open(this.href);return false;
http://postimg.org/image/5m1955afj/" onclick="window.open(this.href);return false;
THD la 10-11W/8R intre 1000Hz si 11000Hz, unde spun THD 0,03%, este DUPA virgula, mai gresesc si eu...
[video]https://www.youtube.com/watch?v=vCcXlap ... e=youtu.be[/video]
http://postimg.org/image/jtqxtsn4f/" onclick="window.open(this.href);return false;
http://postimg.org/image/73raug4jz/" onclick="window.open(this.href);return false;
THD la 140W/8R intre 1000Hz si 11000Hz
[video]https://www.youtube.com/watch?v=tt-6Pgw ... e=youtu.be[/video]
http://postimg.org/image/gcth4kdfz/" onclick="window.open(this.href);return false;
http://postimg.org/image/3mp8rh5hr/" onclick="window.open(this.href);return false;
THD la 1W intre 22Hz-1000Hz
[video]https://www.youtube.com/watch?v=EqPIGu- ... e=youtu.be[/video]
THD la 10W intre 22Hz-1000Hz
[video]https://www.youtube.com/watch?v=VqEdbz8 ... e=youtu.be[/video]
THD la 140W intre 22Hz-1000Hz:
[video]https://www.youtube.com/watch?v=2WtAL6o3H1k[/video]
http://postimg.org/image/4dhyx97v3/" onclick="window.open(this.href);return false;
http://postimg.org/image/il7nlwkjz/" onclick="window.open(this.href);return false;
Test de linearitate la raspuns in frecventa 5Hz-50000Hz:
[video]https://www.youtube.com/watch?v=mF5NbVeRh-Y[/video]
http://postimg.org/image/4st8q9tsf/" onclick="window.open(this.href);return false;
Test de rise time, raspuns in frecventa pina la 1,5MHz, diverse semnale sin dre tri:
[video]https://www.youtube.com/watch?v=YLQsYB8cTGI[/video]
http://postimg.org/image/gut7y5sen/" onclick="window.open(this.href);return false;
http://postimg.org/image/5m5uivztb/" onclick="window.open(this.href);return false;
http://postimg.org/image/p98um8tfz/" onclick="window.open(this.href);return false;
http://postimg.org/image/lffed3c3z/" onclick="window.open(this.href);return false;
http://postimg.org/image/oxre9hczz/" onclick="window.open(this.href);return false;
http://postimg.org/image/z01kyh2j3/" onclick="window.open(this.href);return false;
http://postimg.org/image/4l5ltritr/" onclick="window.open(this.href);return false;
http://postimg.org/image/whfvxsgsv/" onclick="window.open(this.href);return false;
http://postimg.org/image/hrzn713wv/" onclick="window.open(this.href);return false;
Test de max out, suprasarcina, scurt pe iesire, triac crowbarr cum lucreaza la sub 4Hz:
[video]https://www.youtube.com/watch?v=9YgH6A6 ... e=youtu.be[/video]
http://postimg.org/image/j5ra2c367/" onclick="window.open(this.href);return false;
Acesta este un test in care vedem cum se comporta modificarea raspunsului in faza al amplificatorului in banda 10Hz-1MHz, abaterea in banda audio fiind foarte buna, tipic sub 5 grade.
[video]https://www.youtube.com/watch?v=RUh40lM ... e=youtu.be[/video]
Aici avem un test de stabilitate in functie de scaderea tensiuni de alimentare, pina cind ampliful "nu mai are de unde" sa dea ceva la iesire, adica intre +/- 60Vcc pina la +/- 10Vcc:
[video]https://www.youtube.com/watch?v=b55DvNV ... e=youtu.be[/video]
Aici avem un test de stabilitate pe sarcina capacitiva de 1uF nepolarizat si 8 ohmi sarcina la 10000Hz semnal dreptunghiular la diverse nivele audio:
[video]https://www.youtube.com/watch?v=nlH-AxWb9wM[/video]
Iar aici avem un test in semnal dreptunghiular la frecventa de 100000Hz la diverse nivele ale tensiunii de la iesirea amplificatorului:
[video]https://www.youtube.com/watch?v=hqRONoo ... e=youtu.be[/video]
Desi intitial am fost multumit de rezultatele preliminarii obtinute cu acest amplificator, am mai facut niste mici "ajustari" si schimbat niste tranzistori (evident se vor face pe toate modulele), si am obtinut exact ce mi-am dorit, maxim din ce se poate stoarce din schema si placa cu piese.
Am facut 3 seturi de teste la 3 frecvente diferite, 1000Hz, 30Hz si 10000Hz cu putere cuprinsa intre 0,01W adica 10 miliwati si maxim, pentru a evidentia orice nivel de putere s-ar asculta cu acest amplificator, ce vom avea real la iesire, distorsiunile conteaza foarte mult nu numai cind te apropii de pragul de clipping ci si sub1W (cine stie, cunoaste ce zic), teste facute atit pe 8 cit si pe 4 si chiar si 2 ohmi (la 30Hz in special) pentru ca la frecvente joase uneori sub si peste Fs, boxele isi modifica foarte mult impedanta nominala.
Testul la 1000Hz:
[video]https://www.youtube.com/watch?v=LX8V2Cc ... e=youtu.be[/video]
Testul la 30Hz:
[video]https://www.youtube.com/watch?v=tWeRhs7 ... e=youtu.be[/video]
Testul la 10000Hz:
[video]https://www.youtube.com/watch?v=yO4iOz7 ... e=youtu.be[/video]
Voi incerca sa fac si niste grafice THD vs Putere pentru cele 3 teste, gen acesta de la Monoblocul Constellation Centaur:
http://postimg.org/image/4cvx3amtr/" onclick="window.open(this.href);return false;
Am avut timp sa fac si un mic grafic putere versus THD, urmarind inregistrarile video si l-am desenat (cit de cit aproximativ), cam asa arata:
http://postimg.org/image/qntfe4ftb/" onclick="window.open(this.href);return false;
Daca il comparam cu cel de la Constellation Centaur, eu zic ca arata foarte bine pentru ceva lucrat in regim de amator versus un amplificator de peste 25000Usd (monobloc).
Etaj final de inalta calitate audio, Leco v2 mini
Reguli forum
Faceti descrieri cat mai complete ale produselor! Decizia de a prezenta detalii de realizare a montajelor/aparatelor expuse aici apartine in exclusivitate autorului.
Incarcati imagini de maximum 1024x860 pixeli.
DjLeco
- Localitate: Bucuresti
SubBass sub 25Hz NUMAI in compresie.
Re: Etaj final de inalta calitate audio, Leco v2 mini
Excelent. Sincere felicitari !.
