Vind un amp Leco hand made, cu module Leco V1, full stabil 2 ohmi.
Finalii de pe ele sint ceva mai speciali cu SOA de 2,5A/80Vce/1Sec, MJL21195 si MJL21196.
http://www.onsemi.com/pub_link/Collater ... 1195-D.PDF" onclick="window.open(this.href);return false;
Traful este dintr-un Crest VS1100, traf ce asigura dupa redresare si filtraj 2x80Vcc.
Ca filtraj am folosit 4 buc de 12000uF cite 2 in paralel pe rail+inca 2 de 4700uF/100Vcc deci cam 28000uF/rail.
Este un amp full stabil 2 ohm pe canal, limitarea de curent la iesire facindu-se la aproape 35A rms, suna demential, atit pe drivere cit si pe bass sau full range.
Banda de frecvente reprodusa cu maxim 0,5db la capete de banda (aproximat din testele facute) 5Hz-50kHz la full power/2 ohm.
Putere 2x800W/2R, 2x500W/4R si 2x320W/8R la 230Volti retea.
Pret 1250 lei, transport inclus in pret.
0722 644 663.
Citeva poze din timpul constructiei:
http://postimg.org/image/wtwjxzfrj/" onclick="window.open(this.href);return false;]
http://postimg.org/image/45jlurdlb/" onclick="window.open(this.href);return false;
http://postimg.org/image/5b9tobxqn/" onclick="window.open(this.href);return false;
Am facut citeva teste pe diverse sarcini pe iesire, chiar si pe 1 ohm, cit si pe muzica:
Test curent iesire 4 ohm/50Hz:
[video]https://www.youtube.com/watch?v=BwVYN2z ... e=youtu.be[/video]
Test curent iesire 2 ohm/50Hz:
[video]https://www.youtube.com/watch?v=7qaz_T0 ... e=youtu.be[/video]
Test curent iesire 1 ohm/50Hz:
[video]https://www.youtube.com/watch?v=_s_fFe3 ... e=youtu.be[/video]
Test dreptunghiular 2 ohm 50Hz+10kHz+20kHz+40kHz:
[video]https://www.youtube.com/watch?v=V9vQmmy6zNE[/video]
Test dreptunghiular 8 ohm (masurare standard) 10kHz+20kHz+40kHz+60kHz:
[video]https://www.youtube.com/watch?v=ojQ0OBJ ... e=youtu.be[/video]
Test liniaritate la iesire intre 1000Hz si 100000Hz:
[video]https://www.youtube.com/watch?v=1vpoI9xnJEM[/video]
Imagini:
10kHz:
http://postimg.org/image/bxwhhiff3/" onclick="window.open(this.href);return false;
20kHz:
http://postimg.org/image/pg3dtsrkf/" onclick="window.open(this.href);return false;
40kHz:
http://postimg.org/image/homnv8nf3/" onclick="window.open(this.href);return false;
testat si pe muzica, un canal incarcat cu 2 ohmi (boxa+infrabass), celalalt cu 4 ohmi, pe muzica, alegeti 1080p la youtube pt calitate audio maxima:
[video]https://www.youtube.com/watch?v=IZ5flhH ... e=youtu.be[/video]
Ultimele teste si poze astazi:
Prezentare:
[video]https://www.youtube.com/watch?v=D7fx8ih ... e=youtu.be[/video]
[video]https://www.youtube.com/watch?v=5UJ29_F ... e=youtu.be[/video]
[video]https://www.youtube.com/watch?v=co8sjPE ... e=youtu.be[/video]
Vind rack case Thon, 3U facut de Thomann.
Lungime circa 45,5cm fara capace si circa 56cm cu capace.
https://postimg.org/image/6gf122zm7/" onclick="window.open(this.href);return false;
https://postimg.org/image/grrduqrbj/" onclick="window.open(this.href);return false;
https://postimg.org/image/a2kueq5zj/" onclick="window.open(this.href);return false;
https://postimg.org/image/mv8yenhlb/" onclick="window.open(this.href);return false;
Pret 350 lei, pentru provincie se poate numai cu fan courier, taxarea la destinatar.
Vind amplificator cu module Leco stabil 2 ohm si rack case 3U
DjLeco
- Localitate: Bucuresti
SubBass sub 25Hz NUMAI in compresie.
DjLeco
Re: Vind amplificator cu module Leco stabil 2 ohm si rack case 3U
Rack case-ul a fost vindut pe alt forum, pretul amplificatorului scade la 1100 lei, insa transportul pentru provincie NU mai este inclus in pret.
DjLeco
S-a vindut in alta parte, multumesc de hosting!
