TV SHARP MODEL37EM-33S
este blocat mod hotel daca ma puteti ajuta cu ceva solutii ca sa-l pot debloca are telecomanda originala a tv-ului cand intru in menu cere cod va multumesc.
						Re: TV SHARP MODEL37EM-33S
Manualul aici: http://www.sharp.eu/cps/rde/xbcr/docume ... sitetype=2 dar cred ca trebuie sa stii codul care a fost introdus la blocare. Altfel trebuie rescrisa memoria cu dump-ul de aici: http://dump.elektroda.pl/download130.html
Am gasit si manualul service in care iata ce spune la capitolul child lock:
CHILD LOCK CANCEL
The following process describes how to cancel
actual password (PIN) when the customer
forgets code.
1. Switch ON TV set.
2. Press button DOWN * on TV and 0 on R/C
simultaneously.
3. Press MENU button on R/C to input menu.
4. Using buttons UP CH DOWN move to *
position.
5. Press MENU button again.
6. Select PIN and input new PIN (Please do not
forget it)
7. Select EXIT and press MENU button again.
Manualul complet se poate descarca de aici: http://www.fileshare.ro/e29185702
						CHILD LOCK CANCEL
forgets code.
simultaneously.
position.
forget it)
