echivalent tranzistor
cableguy
Localitate: moldova
Mesaj necitit de cableguy »
ce echivalent ar merge cel mai bine la tranzistorul KSP 2907A? si un echivalent la tranzistorul smd W2F . Multumesc.
Re: echivalent tranzistor
petru KSP 2907A cauta datasheet-ul pe net si introduci datele aici: http://www.elbase.eu/echivalente-tranzi ... ustom.html ....vei obtine multe echivalente
in ce priveste celelalt, habar n-am.
cableguy
Localitate: moldova
ADMIN scrie:petru KSP 2907A cauta datasheet-ul pe net si introduci datele aici: http://www.elbase.eu/echivalente-tranzi ... ustom.html ....vei obtine multe echivalente
ok, toata stima.
W2F= MOSFET canal N... /26/ Acum nu stiu pe cine sa cred, un catalog zice una, google, zice alta:
D
A
T
A
SH
EET
Product data sheet
Supersedes data of 1999 Apr 27
2004 Jan 16
DISCRETE SEMICONDUCTORS
PMBT2907; PMBT2907A
PNP switching transistors
db
ook, halfpage
M3D088
2004 Jan 16 2
NXP Semiconductors
Product data sheet
PMBT2907;
PMBT2907A
FEATURES
High current (max. 600
mA)
Low voltage (max. 60
V).
APPLICATIONS
Switching and linea
r amplification.
DESCRIPTION
PNP switching transistor in a SOT23 plastic package.
NPN
complements: PMBT2222 and PMBT2222A.
MARKING
Note
1. *
p
Made in Hong Kong.
t
Made in Malaysia.
W:
Made in China.
PINNING
TYPE NUMBER
MARKING CODE
(1)
PMBT2907
*2B
PMBT2907A
*2F
PIN
DESCRIPTION
1
base
2
emitter
3
collector
Fig.1 Simplified outline (SOT23) and symbol.
handbook, halfpage
2
1
3
MAM256
Top view
2
3
1
ORDERING INFORMATION
TYPE
NUMBER
PACKAGE
NAME
DESCRIPTION
VERSION
PMBT2907
plastic surface mounted package; 3 leads
SOT23
PMBT2907A
SOT23
2004 Jan 16 3
NXP Semico
nductors
Product data sheet
PNP switching transistors PMBT2907; PMBT2907A
LIMITING VALUES
In accordance with the Absolute Maximum Rating System (IEC
60134).
THERMAL CHARACTERISTICS
Note
1. Transistor mounted on an FR4 printed-circuit board.
SYMBOL
PARAMETER
CONDITIONS
MIN.
MAX.
UNIT
V
CBO
collector-base voltage
open emitter
60
V
V
CEO
collector-emitter voltage
open base
PMBT2907
40
V
PMBT2907A
60
V
V
EBO
emitter-base voltage
open collector
5
V
I
C
collector current (DC)
600
mA
I
CM
peak collector current
800
mA
I
BM
peak base current
200
mA
P
tot
total power dissipation
T
amb
25
C
250
mW
T
stg
storage temperature
65
+150
C
T
j
junction temperature
150
C
T
amb
operating ambient temperature
65
+150
C
SYMBOL
PARAMETER
CONDITIONS
VALUE
UNIT
R
th(j-a)
thermal resistance from
junction to ambient
note
1
500
K/W
cableguy
Localitate: moldova
nu stiu ce sa pun in loc si nici nu ma tine sa fac teste pentru ca acesta este in circuitul de comanda a integratului STR T2268 pe care l-am gasit crapat cu alte cond. si diode . Si nici nu prea am gasit mare lucru pe net despre sursa lcd LG model sursa LGP2637TD.
poate ajuta......spune-ne si modelul tv.
strt2268_167.rar
(161.42 KiB) Descărcat de 368 ori
cableguy
Localitate: moldova
ADMIN scrie:poate ajuta......spune-ne si modelul tv.
LG RZ-37LZ55
Vedeti daca nu va ajuta asta: si pe langa asta ,puteti vedea daca este tranzistor PNP daca emitorul este conectat la un + iar colectorul spre un -( bineinteles poate fi si prin rezistente.
LCD POWER - FEL-3237UB - STRA6151 , LA5752 , STRT2268 , FA5501AP.zip
(210.78 KiB) Descărcat de 351 ori
